L
Lightning
How am I supposed to soar like an Eagle when I’m surrounded by all these pigeons.Hey don’t have a pop at us, it’s not our fault we’re surrounded by muppets!![]()
I’ve seen way worse in people’s houses working as a registered gas engineer.
Ah so you can tell us if the butane at this pressure/flow rate has enough energy to create a static issue?I’ve seen way worse in people’s houses working as a registered gas engineer.
I can tell you that that is not the only possible charging mechanism.Ah so you can tell us if the butane at this pressure/flow rate has enough energy to create a static issue?
Agreed.….actually I’ve just realised this is utterly pointless.
I’m staying well out of it lolAh so you can tell us if the butane at this pressure/flow rate has enough energy to create a static issue?
Cable ties on a gas pipe will always look a bit dodgy.
For those of us that are ignorant on these matters, other than replacing the cable ties with jubilee clips and a much longer bit of hose between the bottle and the quick release valve, I have been using a similar set up for years, what is wrong?I don’t like it much. Unless the hoses are electrically dissipative, which they may not be, that metal union is an isolated conductor, which is a potential electrostatic discharge ignition hazard.
If those hoses are designed to be used with gas, and are electrically dissipative, nothings wrong with it. If the hoses are just random hoses found somewhere, and they happen to be an electrically insulating material, it could result in electrostatic discharges from the metal union. As I don’t personally know where all the elements came from, it just makes me a little uncomfortable. Which is why I said I don’t like it much, as opposed to saying it’s definitely not ok, as I am not sure.For those of us that are ignorant on these matters, other than replacing the cable ties with jubilee clips and a much longer bit of hose between the bottle and the quick release valve, I have been using a similar set up for years, what is wrong?
Yes.Thanks, so using one of those quick disconnect valves on camping shop bought gas hoses should be fine.
Might be showing my ignorance here but since I have this setup both in the van and for my outside cooker i’m keen to understand the risks.For those of us that are ignorant on these matters, other than replacing the cable ties with jubilee clips and a much longer bit of hose between the bottle and the quick release valve, I have been using a similar set up for years, what is wrong?
Isn’t this what the valves are sold for?
Have a great day!This makes the “gas on/off whilst driving” debate look sensible!
I am an electromagnetic hazards protection specialist in aerospace engineering by trade, hence the name.Having a person called "Lightning" near a gas installation is definitely a discharge risk.
You could’ve chosen ‘Rod’ instead… but i get why you didn’tI am an electromagnetic hazards protection specialist in aerospace engineering by trade, hence the name.
No lightning rods on planes.You could’ve chosen ‘Rod’ instead… but i get why you didn’t
ExactlyNo lightning rods on planes.
I could have called myself Expanded Copper Foil instead maybe.Exactly
Doesn’t quite trip off the tongue in the same way though, does it?I could have called myself Expanded Copper Foil instead maybe.
Keep on enjoying your day!Sense of humour?
No, bronze mesh perhaps.Doesn’t quite trip off the tongue in the same way though, does it?
