Have you checked the Resources section of the Forum. Those will be fuses for mainly the Habitation area, and haven’t change much between T5.1/6/6.1.I’m sure there is someone on here who could help identify the fuses under the passenger seat on my MY21 Ocean T6.1 204PS 4Motion.
I’d be grateful for any help.
Hi WelshGas, I did try resources but couldn’t find anything to match and there seemed to be a different arrangement of fuses and values for that matter. I’m trying to identify where I can tap off for an amateur radio set.Have you checked the Resources section of the Forum. Those will be fuses for mainly the Habitation area, and haven’t change much between T5.1/6/6.1.
The actual fuse position may vary but the value and fuse box does not.
Multimeter to look for live fuses.Hi WelshGas, I did try resources but couldn’t find anything to match and there seemed to be a different arrangement of fuses and values for that matter. I’m trying to identify where I can tap off for an amateur radio set.
I can get to the leisure battery under the passenger seat. Thanks for the information about the battery negative. Where does that monitoring appear ? Is that on the overhead display?Multimeter to look for live fuses.
But I would consider wiring to one of the Leisure batteries with a fused live and the negative to a chassis ground, NOT the battery negative pole as that would bypass the battery monitoring on a T6.1.
The starter battery is a no no as it doesn't take much to flatten that as shown by the dash radio automatically switching off after 20 or so minutes.
Yes, the Camping Control Panel. The T6.1 has a more sophisticated system , but the graphics and " Hours " display are a little iffy as they depend on spot data, but the voltage is accurate.I can get to the leisure battery under the passenger seat. Thanks for the information about the battery negative. Where does that monitoring appear ? Is that on the overhead display?
