Old Sid
- Messages
- 162
- Vehicle
- T6 Ocean 204
Hi. I’m having problems with the ABS, stability control, tyre pressure monitoring and ACC all failing together. Usually, the fault disappears after driving a short distance but reappears next time I start a drive. I assume this points to a failing ABS wheel sensor. My nearest VW Van Centre is a 5 hour round trip.
1. Is it worth buying an OBD reader to identify the fault? If so, what should I buy?
2. Is it likely to be a wheel sensor, or might it be a more complex issue?
3. Could I trust my local garage with a job like this? (My local VW car dealer say they can’t do it).
Thanks.
Thanks.
