Hello from New Zealand
  • Thread starter KiwiGrandCali680
  • Start date
K
KiwiGrandCali680
New Zealand
Grand California 680
Hello from downunder. We have a 2022 GC680 and loving it so far. We have had a CI Riviera 181 - 6 berth - on Fiat Ducato chassis for 12 years and now getting used to different “living” in smaller habitation area. VW drives like a dream! We have made a few tiny mods (added shelves and bungees) and will make smaller table soon. (Does anyone know where to source folding leg and brackets that slot into rail)? One thing we notice is that habitation battery goes flat in about 2 weeks when left unused and locked up, parked under a carport. ……. anyone have a similar experience?
Cheers 4 now
  • Welcome
Reactions: Sad
Welcome to the forum! You have a very nice van there.
We have a T6.1 Cali, so our leisure battery experience will be different. We’ve found if nothing is left on (such as lights, fridge), then the battery doesn’t go flat when the van is not being used. The control panel should show the amperage being drawn. Since we fitted a dashcam (with an active parking mode) the main engine battery discharges in around 3 days, so the van is kept hooked up to a outlet in our garage. Once the engine battery is topped up, the leisure battery is then topped up (floats when fully charged).
Kia ora. We love NZ, have some great friends in Whanganui - have been over to stay with them times and seen pretty much all of the North Island from the Cape down to Wellington. Last trip over was Jan 2020 - just before covid kicked in. Cannot wait to get back again.
Cheers 4 now
For table hinges that fit the rail, check the unused ones on the underside of the table in the rear door & be brave drilling out the rivets! Alternatively have you tried that small table inside the van? it clips to the rail & only needs one other leg down for it to be stable.
Re the battery drain, someone recently suggested that the Truma heater control panel under the bench is live even with the red switch turned off - may be worth investigating.
Hello Andy, thanks for that. Will check both your suggestions.
Thank you
Hi … yes NZ is pretty amazing. Feel free to call in when you next visit ….
I wouldn't mind helping you with that battery drain by renting it from you a couple of weeks sometime in the future ;)
Jules_Law_NZ1
Off-The-Beaton-Track
FreeBirds
F
G
Jandy61
L
7K
greyplague
greyplague
