![Amarillo](/data/avatars/m/11/11232.jpg?1579901440)
Amarillo
Tom
All AdBlue pumps I have used (from Pamplona to Palermo) have been the same. It seems nuts that VW don't design the AdBlue tank so the pumps cut out at the correct refill level.Hi you can change your dash to liters to convert it go to settings- units change it to liters/km and it will give you the info. Also if the pump clicks out then the tank will be over full unfortunately.
I shall check very carefully next time I refill my AdBlue. Thank you so much for the excellent advice.
