Stephanie
- Messages
- 17
- Vehicle
- T5 SE 180
Hi, My T5 has developed a strange problem. The pump and water supply will only work when the engine is switched on. The fresh water tank is full and the leisure batteries are fully charged but the pump just makes a gentle hum when I turn on the tap. However when I turn the engine on and try the tap the pump engages and water flows from the tap. This suggests to me an electrical fault and I wondered if anyone else had encountered anything similar? The control panel is definitely working correctly because other electrical items like the fridge and lights are working when the engine is off. Very confused
