Thanks - called them, no cover limitYour quote is via a broker, LV do not value your van until they see it to right it off, it’s the value at the time.
speak to them directly. 0330 678 5222
Also worth noting sign in to WeConnect as this immediately notifies you if your alarm is activated internally and externally.Ok - thanks Fellrunner
NFU insurance seems competitive too - I need to call them tomorrow. They specified this requirement….
“Immobiliser Requirement
WE will not pay for loss or damage to the CAR caused directly by THEFT or attempted THEFT, unless the CAR is fitted with a
Thatcham Approved Category 2 Immobiliser at the time of loss.”
The 680 comes with a cat1 alarm and immobiliser ! Which is better than just a cat2 immobiliser (no alarm).
So will have to get that verified
You can check on the Thatcham website.Ok - thanks Fellrunner
Yes thanks, I was looking at that this afternoon, and noted Crafter is cat 1You can check on the Thatcham website.
Link below. Select OEM and then Find Out More.
Thatcham Security Certifications - Thatcham Research
Thatcham Security Certification is a robust verification programme for the assessment and recognition of automotive security products. The certification concentrates...www.thatcham.org
Only if you have a 4G signal. Proper trackers are monitored independently.Also worth noting sign in to WeConnect as this immediately notifies you if your alarm is activated internally and externally.
The Crafter/GC has a CAT 1 Immobiliser and alarm. As WG indicated with his Thatcham link.I’ve just taken out insurance with LV (Not through a broker). I asked about value limits and there wasn’t one - market value of the vehicle apart from the first year which is full replacement value new-for-old. I’ve rechecked my insurance docs this am and no limit is quoted.
We also got a quote from NFU (our local NFU agent) and were about to take that out but as the local office was closed the phone went through to the NFU call centre and they mentioned the Cat 2 Thatcham immobiliser was needed. Hence we ended up going with LV (who were also cheaper). On Friday the local agent called back and said that the GC immobiliser was fine and they would have insured the van - blamed the confusion on the call centre.
