mpill990
Well despite our best efforts to drain down the water system our bathroom tap has been damaged during the recent cold spell. In fact we now have a shower inside of the bathroom cupboard
I can get my hand onto the bottom of the tap and feel the water leaking quite rapidly - although without being able to see I can't tell where exactly it is leaking from. It leaks with the tap off so I'm assuming that one of the unions or the actual tap body has been damaged - oh well...
Anyway the reason for the post is 'how do I remove the tap?'. Has anyone done this job themselves?
It looks as though I have to remove some internal torx screws and then cut away the mastic seal around the sink and lift the whole top section of the sink off?
I'm half thinking of cutting around the top of the tap and then fabricating a removable top plate so that future access will be easy..
Any help or guidance will be very greatfully received.
Mike
Sent from my SM-G986B using Tapatalk
Mike
