OK so after a failed attempt to get my van to VW Van Center...turns out the 8 am start for servicing written on the door actually means 8.30....anyways. Reading Wildcamper's info on the driver side DRL bulb replacement being relatively easy and using the manual Page 416 Fig 315 for H7 I gave it a shot. Came back to let you know how it went...
1. Don't bother messing with the light until the air filter box is off...once that is off you won't lose any skin on the back of your hands. I tried and lost.
2. To do this the little electrical clip...push the grey bit up and away from the clip and then wiggle off.
3. Screwdriver or small socket slacken jubilee clip.
4. Two clips, one in front of you and the other side of the box towards cab, flick them off.
5. Lift box up on the right side and slide to the right to get off. Now you can not only get a hand to the light you can get your head in to see.
6. Remove metal clip light cover and remove.
7. Refer to manual there is an extension piece already fitted to get the bulb out this needs to be turned anti-clockwise as looking at it from the back.
8. This should click round and be able to pull out, bit fiddling but persevere.
9. I replaced bulb with one I got from halfords W21W 582. Just make sure when putting the bulb in the holder that the metal contacts on the bulb are in the correct way and the contacts on the outside of the holder aren't damaged.
10. To replace just do the same but in the opposite order.
![20220624_171435.jpg 20220624_171435.jpg](https://vwcaliforniaclub.com/data/attachments/93/93500-cda9c92eaa831008249abc022150ff46.jpg)
