T
tusu
Hi all, here's my entry question...
Our new Cali is equipped with the (original I believe) D3LP Eberspacher heater. The control unit has been replaced though, and only a timer, Eberspacher EasyStart T (installation instructions attached), has been mounted.
It's my understanding that this modern timer isn't fully compatible with our heater but it seems to work well and it's able to switch on and off the heater at a preset time and for the desired duration. However, there's no control on the temperature level inside the van. So, overnight, we'd either freeze or burn...if none sacrifices to wake up regularly to switch on/off the heater.
I was wondering if anyone here knows if a controller/modulator with embedded temperature sensor could be added "easily" to the timer to do the job. Something like it's shown in the picture below (from page 16 of the attached EasyStart T manual), which really looks like this controller. Problem is that this thing seems to be a standard part for the Eberspacher D2/D4/D5 but, of course, no mention about our old D3LP. Same story for this thermostat, which looks like an alternative to me (although I'm not sure that it can be connected to the timer) and seems to work only back to the D3LCC (model introduced after the D3LP from what I understand).
Any suggestion?
Alessandro
Any suggestion?
Alessandro
