s2bear
Not sure if anyone has mentioned this before but we’ve done it a few times so here goes.
When travelling to the Eurotunnel terminal FROM THE SOUTH, if it’s busy, the queue often tails back onto the motorway slip road and beyond. Even with the new ‘Welcome Area’ (not actually welcoming) this queue can be MASSIVE.
So, drive straight past, as though you’ve missed your turn off. Your sat NAV will then tell you to take the next available exit so you can turn around and head to the terminal FROM THE NORTH. This Queue is often MUCH shorter or non-existent (until you get to the actual terminal that is). I reckon we shaved 45+ minutes off our time doing this on Sunday.
Obviously the actual check-in and immigration process is still an absolute sh*tshow knocking on 90 minutes plus but not much you can do about that. Eurotunnel always blame passport control but I‘m not sure that’s fair. The French check is cursory on leaving (30 seconds). The UK check seems the same as it always has been so I’m not sure where the blame lies.
Anyway. That’s my tip for the day.
