![IanE](/data/avatars/m/0/171.jpg?1424300682)
IanE
![22C62C16-6AC1-4133-B6F0-696DD2AEF58C.jpeg 22C62C16-6AC1-4133-B6F0-696DD2AEF58C.jpeg](https://vwcaliforniaclub.com/data/attachments/28/28709-738e869c47906af52fcb8c6e1bdb3863.jpg)
Any advice gratefully received
Ian
Is that screw missing?View attachment 30274 Just wondered if others had this small but annoying problem and hopefully hit on a solution - the left hand door slides with ease, but the one under the sink has always required a shove to slide it open. We've put up with it until now, but it's beginning to bug me. I've applied lithium WD40 to the runner to no avail. I've managed to get a photo of the sliding mechanism which I insert here. There are two of the parts that are attached to the door itself. It looks like the parts attached to the door are fixed with Allen key style screws - could it be that if these screws are loosened, the sliding action would be eased? They are v tricky to get at and I'm a bit nervous about having the door come loose and getting it back on would be quite tricky. You will have guessed by my poor command of the correct terminology that I'm no DIY expert!
Ian
Let us know how things turn out.Many thanks WG - I did say I wasn't much cop on the DIY front but I didn't appreciate just what a dunce I can be! Believe it or not I hadn't noticed the missing screw - I'll follow your advice.
Thank you - very helpful.Part 12 should give you the missing screw if you cannot find an alternative.
No idea I'm afraid.Not all of these parts can be ordered right, just specific numbers?
Thanks for this - very helpful. I've sent the link to my VW garage - don't know if theres any other way of ordering it. I also guess I'll have to remove the pop rivets somehow if I get the part.No idea I'm afraid.
http://www.oemepc.com
Click on Campmobile, Select Year and then section.
Camping side of things is in Accessories and Body.
Sorry I just realised I didn't report back - I decided to leave it alone. It's not that sticky and I fear that if I attempt improvement I could make it worse. In any event I wonder if it's a common issue?That's really helpful thank you - I think I'll order the part before I go any further but certainly I'll post how I get on.
