On the SE/Ocean it does trickle charge the Engine Battery and I believe the Beach is the same.Hi, just wondered if when my beach in on electric hook up in the garage does it charge the main engine battery too? Or just the leisure battery?
I ask because the Cali will be stored for longish periods over winter so will I need a trickle charger?
Going to struggle to use it much, wife works some weekends and I work in the week. Kids clubs at weekends and so on inhibit the use we would like to do. It has to wait until next year bar the 11th November which will be the first time we use it.I wouldn’t leave a car locked away and unused. Low/no mileage is worse than high mileage IMO.
Cars need to keep warm and running. Lubricants need the heat and usage and fresh air is needed to ward of smells and moisture. Even moisture collecting around metal parts can become affected such as the exhaust.
That’s why I use mine as our main vehicle.
Great believer in cars should be used. Read an article on the Porsche forum about a guy who has covered 400k in his Porsche 911.
Where most lock them in garages, this guy uses his everyday.
Absolute legend.
Definitely keep her on hook-up and worth getting it out as often as possible
We have just bought a New Beach 2017.First strip out and i plug the kettle in the socket behind the passenger seat..Nothing happens.We have driven about 30 mile already.? What do i need to do? Thanks
Hi AliThanks..is there anyway i can make a cuppa 'off hook up'?
and..how do i remove an 'extra seat'.... a complicated thing this Beach!
Campingaz burner, that's what we have and a 230v low wattage kettle if on hook up.Thanks..is there anyway i can make a cuppa 'off hook up'?
Thanks..i'll give it a goHi Ali
I took one of the second row seats out of my new beach yesterday.
Here goes - at the very front (behind the front seats ) of the slide rails are the stoppers. They are fixed into the channels by clips. To release them put you finger into the channel where it meets the stopper and you’ll feel the clip, then it’s a case of pushing the clip and lifting the stopper out.
Either side of the channel is a flange. The front section of this which is about 12” long needs to be slid towards where the stopper was removed. Once there you lift them out. I found sliding these the most difficult part of the whole process as they don’t seem to move freely but I’m sure that will become easier. To lift them out you sort of fold them up and away from the channel.
Once they are out slide the seat forward. There are 4 lugs at the bottom of the seat and you need to line these up with the 4 openings within the channel. I’m sure that could be worded better but should be fairly self explanatory when you’re looking at it.
From that point you can lift the seat out.
It’s worth looking on YouTube for ‘California chris’ as the whole process is covered in one of his videos.
Good luck !
Thank you,Ill go get a Kettle!Campingaz burner, that's what we have and a 230v low wattage kettle if on hook up.
http://www.swissluxx.com
I would also recommend buying a small flat bed trolly as moving these seats is hernia inducing, back breaking work. They are very heavy. These trolleys aren't expensive but are very useful.Hi Ali
Good luck !
We always use a Jetboil in our SE. Way quicker and I suspect less wasteful than using the hob. Jetboil and a Cadac and you're sorted!A JetBoil is the best tea making device for a Beach, in my opinion!
As an aside - I notice that your rear stoplight has parted company with the tailgate, too. We have replaced ours twice now so it's a dab of adhesive next time. I suspect the airtight nature of the Cali pops the lens out when you close a door. I always wondered why my tailgate was tricky to shut properly until my daughter slammed it with me in the car. The pressure almost pushed my eardrums in. Since then I always leave something else open when shutting the tailgate and no more problems getting it to engage first time. My dad had a similar thing with a 1960s Beetle 1300, difficult to close the doors with windows fully shut.Hi, just wondered if when my beach in on electric hook up in the garage does it charge the main engine battery too? Or just the leisure battery?
You can get 12v kettles but they are in my opinion a waste of time, best to just get a small gas device.Thanks..is there anyway i can make a cuppa 'off hook up'?
That is covered under warranty, and they supposedly fixed that with the T5 but looks like it's back. Mine was fixed when in for a service by refitting using stronger adhesive. The dealer said it was air pressure related when closing the boot quickly. Old problem they never seem to have resolved.As an aside - I notice that your rear stoplight has parted company with the tailgate, too. We have replaced ours twice now so it's a dab of adhesive next time. I suspect the airtight nature of the Cali pops the lens out when you close a door. I always wondered why my tailgate was tricky to shut properly until my daughter slammed it with me in the car. The pressure almost pushed my eardrums in. Since then I always leave something else open when shutting the tailgate and no more problems getting it to engage first time. My dad had a similar thing with a 1960s Beetle 1300, difficult to close the doors with windows fully shut.
That's correct - it takes me about 70 minutes to pack the van from a sleeping start, including Vango Kela awning, and about 70 minutes to boil 750ml of water using a 12 volt 20 amp kettle.I think @Amarillo recently quoted, that it took a 70x minutes to boil a kettle from the 12v!!
I've estimated that about 2/3 of the energy is heat loss during the slow boil time, so it makes me wonder if I could make my fortune by going on Dragons' Den with a patented design for an electric thermos flask kettle.
