![Loz](/data/avatars/m/11/11491.jpg?1569356098)
Loz
T6 with euro 5 spec can be done
euro 6 my17 can’t
my18 is now factory standard.
euro 6 my17 can’t
Picked my Ocean up in June, mirrors only fold via switch on door.Mine was build May 2017 has fold away mirrors on switch on door but key fob does not work is it the lock button you hold down
Is that standard that they will fold from locking with the key ?T6 with euro 5 spec can be done
euro 6 my17 can’t
If you venture over the bridge in to Gloucestershire I’d be happy to program that for you if your passing..Picked my Ocean up in June, mirrors only fold via switch on door.
On a bright side found out that if I hold the open button on key fob for more than 2 second the windows open, if press and hold close button on key fob, the windows close
It will be on yours.Is that standard that they will fold from locking with the key ?
PM sentIf you venture over the bridge in to Gloucestershire I’d be happy to program that for you if your passing..
https://vwcaliforniaclub.com/threads/programmable-feature-with-carista.12831/Probably a thread for this somewhere but in a nutshell, what the blinkin' 'eck is Carista, VCDS and OBDelven?
I am guessing from the last title that you plug these things in and it allows you to change some settings?
I agreed with your post though I'm not sure about this bit.One word of warning though leave your mirrors unfolded in icy conditions as having them unfold, or try to unfold, when they are frozen up can damage the motors.
I've seen it mentioned on older posts that the mirrors do not fold on locking.
But looking at this Dutch video of the MY18 changes they also report this has now been added (from 5.06)
Did this change make it to the uk version of the ocean which has folding mirrors as standard?
Can anyone with a recent Build confirm?
I have folding mirrors now and many people asked the same question on the Evoque forum.
There was a customer service rep on there who would take such queries and deal with them. For the Evoque at least, the answer was they are designed to be used all year round.
OK VW may have a different stance but that would be a short coming.
I thought I already did, the mirrors fold on the key from the factory on an MY18..Come on Loz, spill the beans you know it makes sense...
You did here https://www.t6forum.com/threads/how-to-program-folding-mirrors-pictogram.1780/
Rod
Do your windows open and close with the fob still?Mine used to do it on the lock fob activation, but have now decided that they dont want to do it any more from the remote. They work fine on the internal mirror switch though. Ive tried it on the fob on each and every setting in the internal mirror dial. Still nothing. Any ideas anyone?
Hi Loz, yes ive just been to the garage and checked and windows still work on the fob up and downDo your windows open and close with the fob still?
Interesting, so what has changed since the last time you were able to fold them up with the fob?Hi Loz, yes ive just been to the garage and checked and windows still work on the fob up and down
Brilliant, and thank you. I’ll try it on the weekend when I get it out and revert back with results.Okay, door controllers often do this when they lose power or get reprogrammed.
Try and recalibrate both windows by doing this.
Press and hold the window button to drive the window down, when it stops let go and press it down again and hold it for 5 seconds.
Now pull it up (sometimes it jumps up and stops but just pull up again) when you get to the top let go and pull the button up again and hold for 5 seconds like you did on the way down.
Check the one-touch down and up works.
Repeat this on the other door.
Now the one-touch is recalibrated test the folding mirrors.
