MattBW
Here to help
It was in the ashtray originallyIn a SE it has a special place in the toolkit that sits behind the rear seat .
Don't know on the beach...
That's the Scots for you.On hols last summer in the west of Scotland I got a nail in a tyre and then a bolt in the same tyre two hours after it ha been repaired! Is that a record.
Fortunately both were clean penetrations towards the centre of the tyre and were repaired by tyre centres. The tyre is still going strong 6 months / 4,000 miles later. Interestingly a puncture repair is cheaper in Campbeltown than in Leicestershire!
Have you reset the tyre pressures on the dashboard? The warning light won't go out until you do.I read the manual and I don't think it makes it clear at all.....once you've been pointed in the right direction it's ok! I had my true replaced on the drive and all four true pressures checked but my warning light is still illuminated
Everytime the Tyre Pressure Warning light is activated then it will stay ON until reset. It is a "Latching" alarm i.e.: has to be reset after activation.I read the manual and I don't think it makes it clear at all.....once you've been pointed in the right direction it's ok! I had my true replaced on the drive and all four true pressures checked but my warning light is still illuminated
Believe me - I'm an expert now! As I am at using the jack, changing a wheel and fitting / removing the sparesafe .
Welsh Gas/DM is resetting on the dashboard something I can do.....slowly training as a mechanic thanks to this forum!!Everytime the Tyre Pressure Warning light is activated then it will stay ON until reset. It is a "Latching" alarm i.e.: has to be reset after activation.
@Gail seavor this may vary a bit depending upon model. I have a T6 204 DSP. Mine is done from the Steering Whelan controls and MFD.Welsh Gas/DM is resetting on the dashboard something I can do.....slowly training as a mechanic thanks to this forum!!
