mr_waxdope_noodle
Normally no significant water gets under the closed roof, but it can and will then drain out.Does the drain get used when the roof is closed?
The way the roof canvas is folded looks a little odd. Is that normal?
Is it an elastic band? I wonder if the way the canvas is folding is creating a place for water to pool and then slowly seep through. I personally am not a fan of bands. Is the plastic strut in the canvas broken?
A couple of years ago, I got in the van, opened the hatch and about half a bucket of water fell on my head. It had been getting in the roof and pooling in the canvas and slowly leaked through. Hasn’t happened since.
I just thought it looked odd how it was sagged almost into a bucket shape. If water had got in there it would be wet so maybe not.Thank you for your reply. What do you mean odd? I don’t have elastic band yet. Plastic strut? Inside? I think everything is in order. I’ll record a video of folding roof for you. This could be a gravity as I’m park on slope and the roof it not fully opened on the picture.
Mine
My driver side -
Red arrow is drain under plastic cover that pulls off. On mine rubber part tight with no gaps. Yours looks like it might have been removed at some point. Perhaps when roof fix done.
If you want to test the drain working you need to squirt water down it with syringe. Not too fiercely as not to break it. Water should then drip from wheel arch where it leads to. That would at least rule that out as cause.
For a more definitive test. Remove this panel under bonnet to see drain exit. You’ll need a torx screwdriver for that. T30 I think.
This is v useful!
Stanley 097552 1.5 - 8mm Fatmax Locking Hex Key Set https://amzn.eu/d/bW6nF9s
ArunAlec’s thread above may be more similar to your problem. Good luck
It may not be the the drain pipe. Mine leaked around the “rubber” grommet that the drain pipe connects to.
Water Leak - do I need to spend £2500 pounds to replace the infamous roof panel?
I did a test as recommended by an official dealer and poured a bottle of water down the front drain which is under the elevating roof right near the a pillar. Some of the water drains out by the wheel well on both sides but on the right side some water leaks out of the roller blind. I thought...vwcaliforniaclub.com
I’m not sure I have great suggestions. Is there any reason the rubber won’t fit back on better? Why was it wonky? If so I would probably clean around the hole with cotton buds, dry it and put a little bathroom silicone on the hole and then put the rubber back, possibly with a small amount of silicone around it.
Other than that I typed “how to patch small metal hole?” into Google and various products came up. Including -
https://amzn.eu/d/37ING6P
Quite a few different products.
Whatever the reply and solution is, you must win 'best photographs on here' competition for showing what's going on.Pictures from the inside, you can see the light is coming through the hole where this rubber is
Small consolation, I know, but really useful for the rest of us to see what happens under those covers.
A product like Sika Flex can be used to fill that hole and be totally waterproof, the original sealant clearly has a hole in it.Does anyone know where I can fix this issue professionally? Local garage specialising in VWs tried, but didn’t fix the leakage. They said it could be due to some roof corrosion, which is a known problem (as they said). I’m in South East, Brighton area. Please help.
P.S. or at least where can I try to find some help? Bodyshops? Official VW garage?
there other products available from Builders merch, look for a product that is an adhesive sealant all in one & one that will cure under water.
Available in all sorts of colours, suggest either clear or white.
Clean the area fully, mask up the surrounding area (External ) and pump some into the hole so that you are sure it’s gone into to gap, apply a thin bead over the hole & a very thin coat to the underside of the rubber, refit the rubber, wipe off any excess and firmly tape it in position with duct tape or similar (fitted flush & correctly) leave for 24hours Or as the product instructions.
If you cant tape the rubber cap securely down use something to weight it down, making sure the rubber cover is seated perfectly as the sealant will stick like S*#t to a blanket and you wont get it off easily
don’t leave the duct tape on the paintwork for much more than 24hours
if you need to you can apply a very small bead to the edge of the rubber cap after it has been refitted and the initial sealant filling the hole / holding the rubber cap has cured fully.
