VW bike rack lock issue
BristolCali
Bristol
I have a new (second hand) original VW T6 rack and regardless of what position the key is turned you can still tighten or loosen the clamps.
Before I ask for a refund I want to make sure I am operating it properly, should locking stop the twisting action on the clamp?
Thanks,
John
When locked, the plastic knob should still spin but without engaging with the thread, so the clamp stays tight shut.
Mine did this on one of the arms, I sprayed a bit of WD40 into the key hole and it sorted it.
Thank you, I’ve removed them and cleaned and oiled them. All good now.
What size security torx do I need to fit the rack? I don’t have the original tool.
Thanks.
It’s also worth removing the locking knobs, and then apply copper grease to the threads, then replace Knobs.
