C-channel insert
Jody Taylor
Jody Taylor
T5 SE 180 4Motion
Does anyone have experience with the plastic c-channel insert that fits into the standard multirail? I want to use this to attach my Vango drive-away awning to the van rather than the c-channel in the roll-out awning. However, I have read that the insert does not work with a standard 6mm Kador strip.
Iron Van
Iron Van
T6.1 Ocean 204 4 motion
Are you talking about the black plastic/rubber insert that slides into the rail either side of the van? If you are, then I can say that the 6mm Oztent Awning connector kept popping out with the slightest pressure. I was going to try using the figure of 8 plastic strip but have a roll out awning now instead.
R
Richard Teale
Guest User
Not sure whether you found an answer elsewhere, but I've been on a similar voyage of discovery myself and I now have something that works (for me).
I have removed the factory roll-out awning from my Cali (heresy I hear people say). I only used it a few times a year and for the rest of the time I was lugging around 26kg of metal, which spoils the lines of my van (in my humble opinion).
I do however want to connect a canvas sun shade/awning on occasions and I also intend to get a drive away tent awning for a trip this summer. I want to be able to connect these directly to the van (i.e. to the factory fitted aluminium multi-rail that is bonded to the side of the van).
Enter various threads discussing problems getting a 6mm Kador strip (typical of most tent awnings and sun shades) to attach reliably either to the van itself using the aluminium multi-rail or to the awning rail on the roll-out factory awning.
In the end I needed the combination of the figure 8 awning connectors sold widely, but in this instance (as they can vary) from the VW California Owners Club shop (specifically https://vwcaliforniaclub.com/shop/product/figure-of-8-awning-channel-75cm-x-3) and a awning convertor strip sold by Funky Leisure (https://www.funkyleisure.co.uk/double-edge-kador-strip-awning-connector-6mm-to-7mm-10949-p.asp).
This allows me to connect my sun shade awning (also from Funky Leisure - https://www.funkyleisure.co.uk/vw-t4t5t6-sun-canopy-awning--anthracite-grey-6770-p.asp) to the van without it pulling out of the rail. I am hopeful that this will also be the case with whatever drive away tent awning I end up with later I'm the year. But I guess there scope for more pantomime there ;0)
A number of learning points for me:
1) The factory aluminium rail appears to be called a 'multi-rail' by some people - perhaps useful for future searches.
2) Also the said multi-rail has a different profile (T-section) to the channel on the roll-out awning (C-Section).
3) To attach a 6mm Kador strip to the awning rail on the factory rollout awning you need the 'tent adaptor' (that is usual supplied with the vehicle where the factory roll-out awning is fitted, but otherwise a rather pricy VW part circa £80), which is a rubber insert that fits into the awning rail and presents a channel into which a Kador connector can notionally be attached. I say notionally as many threads seem to report that a 6mm Kador is able to pull away from the tent-adaptor, in which case the 6mm to 7mm Kador adaptor strip above may be the answer? I wonder whether the rubber tent adaptor is designed to allow a connected Kador strip to pull away, so as to avoid damage where excessive force is applied - e.g. in strong wind??
4) If your multi-rail has come away from the van (as mine had) then it can be bonded back on with Sikaflex (https://www.funkyleisure.co.uk/sikaflex-221-high-bond-metal-adhesive--sealant--300ml-6560-p.asp other suppliers available). Not difficult to pull the rail away sufficiently to squirt some adhesive behind the rail and then hold in place with something like a ratchet strap until the adhesive goes off. Just make sure you wipe off any overspill while its still wet.
Apologies if this cuts across many threads. Happy to post to the technical section if that makes more sense.
P
pete&gill
T5 SE 174
My van came with the rubber insert from new. Now I have a new awning I find it is impossible to connect to it with a kador strip. As many people have found, the rubber is too soft to hold the bead.
I need to take out the rubber, but having been there 14 years it is stuck! Does anyone have experience of pulling it out without pulling the aluminium rail off the roof?
Ch1pbutty
Ch1pbutty
Burgess Hill
T5 Beach
Bin the rubber insert and just get one of these; (if the rubber is stuck, put some silicone spray on it.)
Sad
Sad
Bridport, Dorset
Cali now sold
Cut it out? Massive risk of taking off your fingers too I'd imagine!!
P
pete&gill
T5 SE 174
Thanks - yes I've got the kit, problem is taking out the rubber
V
vwsween
Birmingham
Cali now sold
Pulled mine off recently. 1 person pushing at the front and another pulling at the rear of van. Came out easily once started. End towards rear needed a bit of wiggling to get going.
Perfectos
Perfectos
Hertfordshire
T6 Beach 150
Silicone spray - it’s used as a release agent for rubber
edit: keep it off the paintwork
Hawthorn37
Hawthorn37
Retired, and working hard at it
Derbyshire, United Kingdom
T6.1 Ocean 150
If you get a drive away kit with 1-into-2 kador strips, 4mm and 6mm on one side, and 6mm on the other side, you can put the 4mm and 6mm together in the channel. Then connect your Fig of 8 strips to the single 6mm kador.
If you already have say a 4mm/6mm kador, just buy a 6mm/6mm and stuff them both in. This is actually what we’ve done. A little less elegant but it works. It’s easy done and from my testing it gives a strong anchor. I’ve done this to attach a tarp awning (Hillcrest) to the passenger side, along with king poles, to make a covered area to cook under, instead of using the wind out sun canopy on the drivers side.
P
pete&gill
T5 SE 174
Got it out eventually, it seems it was sealed in position - see pic. If anyone's interested, it took a mole wrench clamped to the rear end and dragged out with an engine lifting tackle! Phew!
  • Wow
Reactions: Sad
