12v outlet in wardrobe
Campertastic61
Oxford
T6.1 Ocean 150
Apologies if this is an old question, searching is failing for me.
Has anyone successfully put a 12v outlet within the rear portion of the wardrobe in a T6.1 Ocean? It would seem possible since the second leisure battery is in there. Any advice gratefully received.
Wire it +tve to +tve pole of battery and -tve to chassis earth point so that Control Panel battery monitor will see any current draw. In line fuse of no more than 20 amps on the +tve lead.
The leisure battery clamp bolt is a good earth point.
