![RockinNRollin](/data/avatars/m/33/33845.jpg?1688737378)
RockinNRollin
Where to next?
Just one last thought on all this; if the engine was replaced with a 180, you're potentially (as mentioned above) lining yourself up for more issues in the future. If it is replaced with any other engine, potentially you have modifications hoops to jump through? E.g. emissions, does that mean something needs to be changed on the registration or will it be out of kilter at MOT time? Tax/VED? Insurers would want to know too, although in reality they probably wouldn't be that bothered unless the power went up. I should imagine there might be ECU messing required too . . . the more I think about it, the more I'd be inclined to see what repair options (via independents) there are as the first port of call, see what the numbers look like, then take it from there.
Is there an aftermarket EGR solution that can be used as a preventative if the engine is swapped with another 180 (either new or used)?
