GordonH
Has anyone upgraded thier speaker system using this plug and play Alpine one? https://www.alpine.co.uk/p/Products/sound-systems-for-volkswagen/spc-106cra2
I had this as soon as I got the GC. Noticeably more separated sound processing and the unit is very easy to install. Just be careful when putting the A-pillar panel back. If the wiring gets between it will disconnect from the tweeter dom speaker as the original soldering point is weak.Has anyone upgraded thier speaker system using this plug and play Alpine one? https://www.alpine.co.uk/p/Products/sound-systems-for-volkswagen/spc-106cra2
Great. Thanks for the heads up on the A pillars. I’ve ordered the kit and dodo deadn as well as some acoustic foam.I had this as soon as I got the GC. Noticeably more separated sound processing and the unit is very easy to install. Just be careful when putting the A-pillar panel back. If the wiring gets between it will disconnect from the tweeter dom speaker as the original soldering point is weak.
I put Dodo Mat on the door panel but no acoustic liner.
Highly recommended.
This is very interesting Gordon, be good to hear what you think once installed, maybe a little one of your quality “hot to’s” alsoGreat. Thanks for the heads up on the A pillars. I’ve ordered the kit and dodo deadn as well as some acoustic foam.
Brilliant thanks. The habitation area speaker sounds intriguing. Look forward to seeing this.Yes. Was going to take photos etc of the install and share process. Also got a habitation area speaker ‘upgrade’ planned. Will share if successful
