YesWe have a hose pipe ban in force in our area (Southern Water) my understanding is I can fill up our van's water tank at home with our hose pipe. Is this correct?
I’m sure many people with fixed tanks in campervans, Motorhomes, boats and the like will be thinking about this, especially in situations where the use of a hose is in public view. My ‘common sense’ response would be, it’s for potable / drinking use, and what you’re doing at home is no different to topping up water at say a campsite, so it’s not banned.We have a hose pipe ban in force in our area (Southern Water) my understanding is I can fill up our van's water tank at home with our hose pipe. Is this correct?
Pop over to West Sussex….. Southern Water haven’t imposed ban ……..yet!We have a hose pipe ban in force in our area (Southern Water) my understanding is I can fill up our van's water tank at home with our hose pipe. Is this correct?
Agree with @Hawthorn37 - I had a quick look and read it the same - going away in the van for a weekend could be classed as domestic recreational so it's a little grey.I’m sure many people with fixed tanks in campervans, Motorhomes, boats and the like will be thinking about this, especially in situations where the use of a hose is in public view. My ‘common sense’ response would be, it’s for potable / drinking use, and what you’re doing at home is no different to topping up water at say a campsite, so it’s not banned.
However, each water company has its own interpretation of a hosepipe ban, and you should check the wording. For Southern Water, the headlines look OK for filling a van, but looking at the detail of what they say
Drawing water, using a hosepipe, for domestic recreational use - no exceptions
If you’re concerned, Id be tempted to call Southern Water, or trawl their FAQs pages, to get closer guidance.
Apart from that, to make it more obvious to all around, I would use a blue hose, for drinking water.
Doesnt need to go that far, Portsmouth Water don't have a hosepipe ban.Pop over to West Sussex….. Southern Water haven’t imposed ban ……..yet!
there is a difference between domestic and domestic recreational, Yorshire water are specific that filling a tank for domestic use (drinking, washing up, flushing toilets and the like) with a pipe is perfectly ok.Should be able to fill on a campsite at least? Maybe worth gaining the view of one of the clubs, like CMC ??
Looks like the ban in the South of England is growing, to Thames now.
So, I think I see that the consensus on the autosleeper forum is : yes filling by hose at home is probably against the rules and you could be fined, but the water companies won’t comment; filling at a commercial premises (a site) is allowed; if you want to fill at home, go out and buy a long spouted watering can or similar. Its only 30 litres so that’s only 3 x 10L watering can fills.Technically it is a hosepipe ban:
A “hosepipe” means anything designed, adapted or used to serve the same purpose as a hosepipe. This means garden sprinklers and most irrigation systems, connected to the mains water supply, are all considered to be hosepipes, together with anything attached to them like pressure washers.
If needed this weekend I'll just use my water container and fill from the tap, using that to fill the tank.
I'd question the "domestic" recreational use - you're leaving home in the van so not strictly domestic, but is recreational.
Pretty sure that a business can still supply so sites should be fine.
There is a pretty active discussion over here - https://www.autosleeper-ownersforum.com/t39520-hosepipe-bans-and-motorhomes
Aye - that's more or less what I'll do with my big water container.So, I think I see that the consensus on the autosleeper forum is : yes filling by hose at home is probably against the rules and you could be fined, but the water companies won’t comment; filling at a commercial premises (a site) is allowed; if you want to fill at home, go out and buy a long spouted watering can or similar. Its only 30 litres so that’s only 3 x 10L watering can fills.
I'm not affected by any hosepipe ban, but this is what I do anyhow as it is as quick and simple as using a hose given the position of the various internal and external taps at my house.if you want to fill at home, go out and buy a long spouted watering can or similar. Its only 30 litres so that’s only 3 x 10L watering can fills.
Do you need a water abstraction licence from the Environment Agency? (or any other licencing body)But we have a 12m deep well in the garden fed by the River Adur connected to a submersible pump.
All these things may be read in different ways by different people or organisations but their meaning is ultimately subject to what a court decides, if it ever comes to that. However, it seems obvious to me that a definition of domestic use will be different to the definition of domestic recreational. That difference is based on how the water is being used (for example to clean your teeth = domestic and fill a hot tub = recreational) and has nothing to do with whether you are in a recreational vehicle. Its the water use that counts and domestic does not mean you have to be at home.Agree with @Hawthorn37 - I had a quick look and read it the same - going away in the van for a weekend could be classed as domestic recreational so it's a little grey.
That sounds like a typical water company reply.I phoned Southern water and they were not prepared to give me a definitive answer. I have been to a couple of sites so filled up when i got there!
The chances of getting a fine for filling the vans 30 litre tank with a hose is very close to zero, don't sweat it.We have a hose pipe ban in force in our area (Southern Water) my understanding is I can fill up our van's water tank at home with our hose pipe. Is this correct?
Concur.The chances of getting a fine for filling the vans 30 litre tank with a hose is very close to zero, don't sweat it.
