Looking forward to the step by step guide and the secret to getting at the water pump!I've had 3 different issues already with the water system in the California. I've learned a few things as I fixed all of them, including replacing the water pump myself, so I decided to document it all in case it helps others. Here's a first guide on how to identify which problem you are actually experiencing:
https://medium.com/@maxi-mizer/fix-vw-california-ocean-coast-kitchen-water-issues-43a19d0d893a
I hope it helps! I'll update this thread as I complete the detailed step-by-step guides (feel free to drop by that article and give me some claps and comments for motivation!)
Great post looking forward to your guides cheersI've had 3 different issues already with the water system in the California. I've learned a few things as I fixed all of them, including replacing the water pump myself, so I decided to document it all in case it helps others. Here's a first guide on how to identify which problem you are actually experiencing:
Is there any in particular you think will be of particular interest? Happy to start with whichever people will find more useful.Great post looking forward to your guides cheers
Our particular problem was that the pump had stopped working and the 5amp fuse had blown after then changing the fuse and turning the tap on to check, the fuse blew again! The tap does make a click noise when turning on but no noise from the pump!Is there any in particular you think will be of particular interest? Happy to start with whichever people will find more useful.
Cheers
You could rule out the microswitch using the shower and seeing if that starts the pump. If you idon'thave the shower you could force the connection (removing the drawer and bypassing the tap) or testing with a multimeter at the pump's connection by the water tank. You could also look at whether the camping control display shows any leisure battery drain when you open the tap, but that will probably blow your fuse from what you are saying. With that in mind, it would seem to me as if the microswitch is OK (the click doesn't have anything to do with it, mine clicked but the microswitch didn't make a good connection and didn't start the pump) otherwise the fuse wouldn't blow if it did nothing.Our particular problem was that the pump had stopped working and the 5amp fuse had blown after then changing the fuse and turning the tap on to check, the fuse blew again! The tap does make a click noise when turning on but no noise from the pump!
Would this suggest that the pump has seized which keeps blowing the fuses?
Thanks for your advise! Really appreciatedIf you are feeling adventurous or want to give it a go this weekend, someone on this forum had water pump issues and replaced it but then messed a bit with the old pump, to find out it still worked. He just had to push on the propeller (bottom of the pump). If you search the forum you should be able to find it. I still have the one I removed from my van, so I will give that a go and see if I get a spare pump. Might be the same issue you have and if that is the case you don't have to replace it or even disconnect it. Just opening the water tank lid (which is no easy task. I used pliers and a wrench and combined those as a "water tank opener tool". It's somewhere in the forums as well).
