![mikeelawson](/data/avatars/m/23/23823.jpg?1601018599)
mikeelawson
BOOMEL
DSGCorrect. Do you have a Manual or DSG gearbox?
Just get a couple of wheel chocks, quite small and work fine.But then I have turn seat while in gear?
I use these collapsible ones, work fine...Just get a couple of wheel chocks, quite small and work fine.
We need a video of that contortionist activity!Ride up onto the ramps untill you're in the right position and then put the handbrake on. Then put your foot on the break pedal and press it down while you release the handbrake. Now turn the chair. I can do this by myself, allthough I would not recommend it. It's easier when someone else turns the chair while you stay out of the way enough, but still keep your foot on the brakes.
In that case when placed in P - Park, the gearbox and driveline is locked. Handbrake can be taken off and the vehicle won’t run away.
Test it yourself. Find a slight incline. Come to a stop using the footbrake. Put the DSG into P and then release the footbrake, without putting handbrake On. At most the vehicle might rock a little, and I mean a little, but won’t move forward/backwards.
You could also use chocks as well. I don’t myself.
Is this a joke?Ride up onto the ramps untill you're in the right position and then put the handbrake on. Then put your foot on the break pedal and press it down while you release the handbrake. Now turn the chair. I can do this by myself, allthough I would not recommend it. It's easier when someone else turns the chair while you stay out of the way enough, but still keep your foot on the brakes.
Like this?Ride up onto the ramps untill you're in the right position and then put the handbrake on. Then put your foot on the break pedal and press it down while you release the handbrake. Now turn the chair. I can do this by myself, allthough I would not recommend it. It's easier when someone else turns the chair while you stay out of the way enough, but still keep your foot on the brakes.
Is this a joke?
