I specked all season tyres when ordering but it arrived on normal summersJust noticed that I can spec ether All Season or All Weather tyres instead of the standard ones. Does anyone know the difference and which would be the better choice.
All season and all weather tyres are both listed as a £162 cost option, at the moment, so I assume if you ordered them they should supply them or refund the £162.I specked all season tyres when ordering but it arrived on normal summers
Was advised VW not specifying any more. So check with dealer.
Hi yes the dealer Breeze kindly sorted it out just prior to handover a nice set of Michelin Agilis CrossClimate.All season and all weather tyres are both listed as a £162 cost option, at the moment, so I assume if you ordered them they should supply them or refund the £162.
Main difference in the Cali options is that All Season is now a super-low rolling resistance 103H load/speed rated, 235/55/17 was V rated previously and no super-low rolling resistance--the mind boggles..Thanks. Just found this...
The difference between all-weather and all-season tires really comes out when the pavement is wet, so imagine the difference in snow and slush conditions.
Of course, a winter tire outperforms an all-weather tire in the cold season, hands down. But all-weather tires are much better than all-season tires in the winter, while performing significantly better in the summer when compared to winter tires
Apparently all weather tyres are superior to all season tyres in most situations, summer, winter, wet or dry and are a cross between all season and winter tyres. The downside is the rubber is softer than all season tyres so they won’t last quite as long. I’ve decided to get the all weathers.
Were the comparisons between All Season and All Weather tyres looking at 3 Peak rated All Season or the older American just M&S rated tyres? Mention of pavement instead of usual road surface.Thanks. Just found this...
I've never heard of 'all weather' tyres as a separate category, sounds like VW BS. In any case don't worry too much about exactly which tyres you end up with, there's not a huge amount of difference in test results between the various all seasons variants from different manufacturers. As long as they're black and more-or-less circular, they'll do for a Cali.I’m totally confused now! Apparently the all seasons are a little more comfortable and quieter, as well as longer lasting. Oh well, I‘ve ordered mine now...
I did the same - twisted logic meant I spent the DtD discount on options. I ended up with Eurovans Crawley, whose proactive comms has been non-existent. I hear eg. SMG will price-match, and perhaps don't have over 100 Californias on order so may actually call you occasionally. I call Eurovans and they seem to know very little from the factory. Oh well I've been waiting 7 months for a delivery date...what's another few...?I’m totally confused now! Apparently the all seasons are a little more comfortable and quieter, as well as longer lasting. Oh well, I‘ve ordered mine now...
Went a bit mental with the options but used ‘Drive the Deal’ who have already negotiated the discount. You still buy direct from VW, who add £350 admin to pay Drive the Deal, so your contract is with a VW van dealer.
VW Configured spec was £79,003. Drive the deal negotiated price £70,419.08, so a saving of £8,613.92 from list even after the £350, which was included in the £70,419.08. I’m not sure I could have negotiated that kind of a discount myself.
ah, I was not aware that UK was also transitioning from M+S towards the 3PMSF. Good to know for future trips!Unless the M+S have the snowflake -
But this new law applies in 2024. I think its aimed at the Chelsea Tractor owners.
Don't forget, when you have those tyres fitted, your max recommended speed is.
Not wanting to confuse this thread even more,In Germany, this is already a fact.
I think all DTD orders go via Eurovans CrawleyI did the same - twisted logic meant I spent the DtD discount on options. I ended up with Eurovans Crawley, whose proactive comms has been non-existent. I hear eg. SMG will price-match, and perhaps don't have over 100 Californias on order so may actually call you occasionally. I call Eurovans and they seem to know very little from the factory. Oh well I've been waiting 7 months for a delivery date...what's another few...?
Be careful when viewing Americas based videos as tyre description terminology can differ to European..Try this link. All Weather v All Season (they are not the same). Test above is just about different All Season brands.
Test done on cars rather than Cali‘s but should give you an idea of the superior snow performance of all weather, although they do wear more quickly. Some All Seasons can’t be used in Europe during the winter months.
I have specced All Weather tyres on my new Cali as I will be driving in Europe in Winter.
Thanks for the link… Although I’m even more confused, as it suggests that All Weather and All Season tyres are basically the same, but VW offer an All Season and an All Weather (which they suggest is better for snow than their All Season - VW UK confirmed before I selected the All Weather’s).Be careful when viewing Americas based videos as tyre description terminology can differ to European..
All-Weather Tires vs. Winter Tires: What's the Difference?
The right tire in the wrong weather can be inefficient and dangerous. Read this comparison of all-weather tires vs. snow tires to see which ones right for you.www.firestonecompleteautocare.com
