H
haydnw2
We have a T5.1 SE with a bendy LED lamp in the roof and no USB socket.
I've seen previous posts referring to replacing it with the Osram Co-pilot with L+7 fitting. However, the Loox version has the advantage of two light levels plus two USB charging ports. There are installation instructions available, but no indication of how far apart the 4 (not 2 like the existing base) screws are, plus it also states "In order to make optimum use of the USB charging, a driver with at least 20 W must be used", whilst Amazon says "Driver NOT included".
Has anyone replaced their lamp with the Loox version at all, and if so how did it go? Is there any way of knowing what power VW driver is running the standard LED? I realise the obvious solution here is just to buy it and try it, but I'm notoriously rubbish at anything practical, so keen to learn from anyone else's experience first if possible! Many thanks.
LED Flexible Reading Light 12 V, Ø 36 mm, for Surface Mounting, Loox LED 2034 - Häfele U.K. Shop
Lighting With 2 x integrated USB charger ports, Black finish - order in the Häfele U.K. Shop.
www.hafele.co.uk
