![Borris](/data/avatars/m/10/10155.jpg?1445071610)
Borris
Well the simple answer is it looks wonky but it does give peace of mind. So if rain is forecast whilst you are going to be either out or asleep over night you must do it. The thing you have to do once you've dropped a corner is to retighten the hold down straps as they will be loose.Hi Boris, thanks for the extensive post. I have seen one in situ and get what it does, but have only ever seen it with the wind out awning perfectly straight, with the rail parallel to the ground. I was just wondering what effect dropping a corner has on the structure ot the awning room. It must sag at that corner.
I also drop one corner of my awning if rain's likely. But with a driveaway awning attached with the windout wound out, or a tarp, it's easy to compensate.
