![Perfectos](/data/avatars/m/16/16727.jpg?1530734616)
Perfectos
Glad to hear the worst case scenario didn’t happen and the roof is OKJust a final update on my awning accident. The good news is that the roof after all , wasn't bent. As one of you had suggested , it was the bent awning bracket that was distorting the roof, and consequently the bracket to which the top up release clip was attached , was also being distorted. Removing the awning brackets has sorted everything and the roof is fine.Thank you all for your very helpful comments and advice.
Ive decided not to replace the awning. Im going to look at at purchasing a drive away awning instead.
I still have the damaged awning and bent brackets. One of the awning legs is twisted . I wondered if it would be of any value to someone and wondered if I should put it on eBay .I suppose someone might be interested and particularly someone with mechanical know how ??
Im now looking at possible drive away awnings and wondered if anyone had any experience /advice on these ?
I wouldn’t write off the idea of the awning for good, get some use out of the van to establish how you use it, that will help with the thought process
