Loz
I gonna check it, thanks for replyI think your battery 75A fuse is blown (you may have blown it when you removed it because the cable is still live from the front battery.)
It should link similar to this;
Have you checked this fuse?
@Roger Donoghue did you ever get a reply to this question?Thread ressurection. Just installed a kit into a 6.1 ocean, with dual charger, and have done many before with zero issues. Pleanty of 6.1 Oceans done.
On this one, the Starter Battery live side on the split charging relay is dead. The relay works, and energises on startup, but the Starter side just then just shows the LB voltage (as the relay is now closed). Engine off, and the relay clicks open, and the starter side is dead again. More below image.
I connect to the right of the relay, which is always fine. Until today. Cali control panel confirms there is no engine charging happening.
So, .... where is the fuse for the relay to starter battery link in a 6.1 ocean? I had a look under the bonnet and only found two strip fuses on top of the battery, going to two red wires. Both strip fuses checked out OK.
Does the 6.1 also have a fuse panel under the front leisure battery? I didn't want to pull the battery out as I would not have had a fuse to replace ti with if I did find it.
Great information @Roger DonoghueYep - customer had a blown main strip-fuse. They are located under a cover - don't have the details to hand.
If the right hand battery icon on the Epever display shows up, at all, then its connected. "Start" is what its labelled as. If its not connected then no battery icon shows at all.
If you want to test your relay with a meter, then right hand connection to positive meter lead, chassis earth to negative meter lead - you should get around 12.6v. (you can open the bonnet and meter your starter battery direct to see if it's the same, to confirm you have the right one) Prob a touch less than 12.6v unless you've driven recently. The left hand relay connection should meter whatever your leisure battery voltage is at that time.
The Evpever won't charge the starter unless it drops down under 12.6v, OR, the panel has loads of unneeded power and can spare it. The "start" battery icon will almost always sit at "half full" as that is actually 12.6v, which is 100% full, but it has to leave some bars to allow for showing a higher voltage under charge. The starter charging with the Epever is solely meant to be a maintenance / emergency charge.
I’ll give the Solar panel a clean tomorrow and put fridge on and see how it goes …On a Cali Ocean (2 batteries) your fridge should run on medium for about 4 days. No solar. No charging.
With 100w solar, it should run, in summer, ....for ever.....
We can verify this. We had our fridge on for a weekend party to store food overflow for 4 days. The hot weekend we had thats seems to have gone now. Full batteries from the panel.On a Cali Ocean (2 batteries) your fridge should run on medium for about 4 days. No solar. No charging.
Thank you.We can verify this. We had our fridge on for a weekend party to store food overflow for 4 days. The hot weekend we had thats seems to have gone now. Full batteries from the panel.
agree with above, our Dometic coolbox has been switched on in the back of the van 24/7 for 2 years now - doubles as a beer fridge at home…it’s never run out of power.We can verify this. We had our fridge on for a weekend party to store food overflow for 4 days. The hot weekend we had thats seems to have gone now. Full batteries from the panel.
