Washer jets 2007 T5
BikerGran
BikerGran
Growing old disgracefully
Dorset
T5 SE 174
My washer jets aren't working, I can hear the pump going, and a small amount of foam appears where the I think the jets should be, but no sprtay. I can't find the jets, and although I can't think why, I'm wondering if they were moved or removed when they were fixing the bash on the side. I'll go back to the repairers but I don't want to make a fool of myself, so could anyone post a picture of where the jets are? 2007 T5.
I did look in the Haynes manual but honestly it's the most useless Haynes I've ever had!
My 2006 LHD Cali has the jets built in to the wiper arms
Mine are mounted under the bonnet. Obvious to see if there are there.
Hope the photos help a bit....
Big plastic jet sticks out of the underside of the bonnet and sits in the cutout of the plastic cowling when the bonnet is shut.
One per side.
Mines a 2008.
I know it may seem obvious, but is there fluid in the reservoir? The low fluid sensor may not be working.
Topped up the fluid just in case but it didn't need much. I was looking in the wrong place, I'll have another look tomorrow in the light.
Thanks both!
Thanks both!
Check the corrugated washer pipe near the near side bonnet hinge, especially when operating the washer. Maybe a split in the pipe? Easily fixed with some Electrical tape. Pipe moves a lot with bonnet opening. A weak spot.
