Rear aircon water outlet.
T
TripleBee
N/A
Couldn't find this at first sight, so here a picture for you all to not worry.
If you see this, behind the right rear wheel, it is just the water outlet from the 3 zone climatronic at the rear.
The front outlet is in the engine bay, and will drip on the engine cover plate at the bottom and then just drip on the ground somewhere behind the front wheels.
Have you found the panel where the end of the sliding door rail is freezing cold and is covered in condensation?
