![bigmac77](/data/avatars/m/10/10810.jpg?1610374775)
bigmac77
What is a T5gp?At the moment it’s some T5gp and T6 models but I suppose it all depends on how hard you guys push vw![]()
T5.1, the Facelift T5.What is a T5gp?
What is a T5gp?
What is a T5gp?
Thanks. To think I own a T5gp and never knew it.GP is German shorthand for a big product change - Grosse Produkt wanderung (something like that anyway!)
As others have commented, a major facelift T5 to T5.1 as we have come to call it.
Sorry if this is a numpty question. What is an earlyT6? We are Nov 16.
I stand to be corrected but I think that the first ones arrived very late 2015.Sorry if this is a numpty question. What is an earlyT6? We are Nov 16.
Yours is an early one then. Pre the tape which was just after. Got mine in Jan 17 and just missed the tape “fix”
At least that’s what I’m assuming.
Mike
The amazing thing is that the tape is still not automatically being used in the repair. My T5.1 was fixed in November with no sign of tape being used and I believe that this has also been the case with some T6 repairs. I wonder if mine will be recalled to have the tape fitted. I doubt it!Correct the tape fix started in production mid Jan 2017
My late 2015 65-plate T6 is going in for it’s second service in a fortnight before we go to Italy - I’ll phone them tomorrow and make sure that it’s going to get taped-up ...
Thanks for the heads-up.
It may not be that simple it would appear the parts are on back order at the moment and the repair itself may need to go over 2-3 days if corrosion is found on inspection if no corrosion is found then it will be a day job when the parts become available
WORD OF WARNING...!!!
My 2012 Beach had the roof repair which is slightly different to this, however it went to an “authorised VW Body repair shop”.
When they say authorised, it’s sub-contracted out to the lowest bidder.
The work was a shambles and had to go back 3 times and still wasn’t fixed properly after the third attempt. I think I was without the van for 12 weeks in total last year.
I have since got rid of the van and changed into a 2017 model.
I would be very reluctant to allow VW to ferry my van off to the other end of the country for a roof/body work repair again...
Just back from dealers having had two unrelated issues fixed (one under warranty and the other a service issue) and had no mention of roof recall. I hadn’t seen this thread before I went, otherwise I would have asked. Mine’s March 2017.
Thanks Mike, that’s what I thoughtYours should have the tape already as post Jan 2017
Mike
VW have introduced a recall for the well documented issue of roof corrosion / paint bubbling below the seal. The roof will be inspected with the seal removed and if ok protective "foil" will be applied.
I dont have any info regarding what will happen If not ok but I will find out today / tomorrow as my van is being checked for this recall today.
