Smiffy4bikes
Afternoon all
Please see the images below of the exterior water/hook-up panel on my Cali Ocean.
As you can see the front half (front as in towards the front of the van) is proud of the bodywork by a good 1/4 inch. As you can also see, an Ikea pencil fits easily in the gap. (there is also a random pin-prick hole that appeared from nowhere on the front of the panel, but I digress...)
Now, this is not a new problem. I noticed this not long after I picked the van up and immediately informed the dealer. The gap has in my view got larger over the last few months. I've done almost 10,000 miles since collecting the van at the end of January this year. There is a pre-drilled hole in the bodywork almost where the ikea pencil is, as if the panel should have a ‘plug’ which slots into the hole. The panel is flat at the rear, no plug or similar.
The dealer has looked at it and told me (or at least the service engineer has) that a) its a warranty issue and b) its not an uncommon fault. He also said it will require a new panel. And, will take 2 days to fix as the kitchen has to be removed
This is a big worry to me as given that the kitchen is installed at the factory by a robot, I fail to see how a dealership can simply just remove it and then plop it back in, so to speak. Now, I have no issue thus far with the dealer, who was happy to fix it straight away (back in June) but I said I’d rather wait until the end of the summer as I had loads of trips booked up. This was deemed to be fine, and they await my call to book it back in.
My other issue is that the van is my daily driver, so I will need a courtesy vehicle whilst its being fixed. Is this reasonable to ask for given thats it’s a warranty issue? And, as the dealership is a 4hr round-trip from me, again, would it be unreasonable to ask that the Cali is collected, a courtesy car delivered and then returned and swapped once fixed?
Anyone else had this problem?
Thanks in advance peeps....
