Never had this problem even at 140 km/hr on the Autobahn ( 90mph ).I'm getting wind whistle above 60mph on the drivers side. Assuming it's the awning as the door seal seems to be in good order. Has anyone solved this or is it a matter of turning the radio up?!
Can I use wd40 for this or is there another product that you recommend ?Sliding side window seal probably not seating fully . I had this last year . Silicone spray / grease works well on seal and window shuts much easier and will help reduce chance of water leaks which are common .
Wd40 is oil based and will damage rubber seals . Silicone spray/grease is best . Good for stopping rubber seals tearing when frozen too.Can I use wd40 for this or is there another product that you recommend ?
Silicon spray applied but am pretty sure it's the wing mirror seal. Will investigate and report back!
Whistle easily cured! Caused by turbulence between mirror and mounting. I made an out ofSilicon spray applied but am pretty sure it's the wing mirror seal. Will investigate and report back!
Sorry cut short! The whistle is caused by turbulence between mirror and mounting. I made an aerofoil out of a wiper blade rubber about 1 1/2 inch across the gap and stuck it on with ext double sided tape.Sends the air over the arm supporting the mirror. No whistle!Whistle easily cured! Caused by turbulence between mirror and mounting. I made an out of
That's excellent! I'm going to try the seal first though. All was well until I used the retraction button. Suspect something inside disturbed. I'll report back once I've done tools (camping just now) but I love your work around!Sorry cut short! The whistle is caused by turbulence between mirror and mounting. I made an aerofoil out of a wiper blade rubber about 1 1/2 inch across the gap and stuck it on with ext double sided tape.Sends the air over the arm supporting the mirror. No whistle!
Wind it open 1 metre and re-close. I cannot see how having water pooling on the awning would bend anything along the cover.I'm getting a whistle I never had before I went to the Lower Lode meet and forgot to lower one corner of the awning which filled with rain and sagged in the middle. It sprang back into shape when we pushed the water out and I thought we'd got away with it but now the awning doesn't quite close properly, the lower part sticks out, just a little.
I can probably tolerate the sound, thinking that might be safer than trying to bend the awning back into shape.
Ahh. You didn't mention that the awning had collapsed.There was so much water that the awning collapsed and I think the bit where it joins the legs may be slightly bent - I've tried the winding it out and re-closing. See how the bottom part is sticking out?View attachment 20733
Nice Gurney flap. Good effort. You'll be using flowviz next.Sorry cut short! The whistle is caused by turbulence between mirror and mounting. I made an aerofoil out of a wiper blade rubber about 1 1/2 inch across the gap and stuck it on with ext double sided tape.Sends the air over the arm supporting the mirror. No whistle!
