Sorry, no idea how to remove/replace.Hi All, one of my Xenon bulbs has failed and I want to replace it. Have anyone any tips on removing them. Do they clip in or just twist out. Cant find anything on forum or on You tube ???
Blimey, even brighter! I worry that I'm blinding oncoming traffic as it is!Just to let you know I replaced the bulbs yesterday. Actually a lot easier than I thought, and the you tube video's would suggest. No need to remove headlights, simply removed the large black cap, twist the bulb and pull out. Unplug cable from bulb, grab new one, plug cable back in, and insert bulb and twist/lock into position. I would say no more difficult than replacing a standard bulb.
Anyone with Xenon, I recommend upgrading to OSRAM XENARC NIGHT BREAKER UNLIMITED D3S HID, xenon headlight bulb. They are same wattage but much brighter. Noticeably so when driving...
Oh an I did not disconnect the battery just wore latex gloves
Thanks for help ..![]()
Would you think it a good idea to carry a spare if it's so straight forward to fit ? What do they cost ? Thanks .Just to let you know I replaced the bulbs yesterday. Actually a lot easier than I thought, and the you tube video's would suggest. No need to remove headlights, simply removed the large black cap, twist the bulb and pull out. Unplug cable from bulb, grab new one, plug cable back in, and insert bulb and twist/lock into position. I would say no more difficult than replacing a standard bulb.
If you're planning on going abroad it's a legal requirement to carry spare bulbs in some countries so yes, get one.
