Thank you!It comes from the Club Shop
https://vwcaliforniaclub.com/shop/product-category/cali-essentials under the Cali Essentials section £12.99
Many thanks!
Did you question the dealer as to why it's needed? Surely that leaves VW wide open for claims as if the PROS need one in the showroom what chance has an owner got.Was looking at some T6 Demo's today and all the showroom Cali's were fitted with Bellows Bungees!
Spot on from the club shopWhere did you get it?
The problem is there is more collective knowledge on this site than in any Dealership.Did you question the dealer as to why it's needed? Surely that leaves VW wide open for claims as if the PROS need one in the showroom what chance has an owner got.
What conditions can't you use it in then?The problem is there is more collective knowledge on this site than in any Dealership.
If you follow the VW Instructions to the "T" then you will not have a problem, but then you would not be using the elevated roof in many of the conditions Forum members have experienced routinely especially if they use their vehicle all year round.
Unfortunately, judging by some of the questions asked on the Forum, it seems that reading the Handbook is not high on some owners lists, so the Bungee is a help, and judging by some of the cockups made by your VW PROS they need all the help they can get as well.
Storm conditions - not unknown in the UK. Le Mistral, if in an exposed position.What conditions can't you use it in then?
Thanks for the info and taking time to replyStorm conditions - not unknown in the UK. Le Mistral, if in an exposed position.
It can be used but extra care needs to be taken, positioning of vehicle with rear into the wind etc: and care with lowering roof. Common sense really, but then VW wouldn't advocate it.
What if the wind has switched direction in the night , like it often does?Storm conditions - not unknown in the UK. Le Mistral, if in an exposed position.
Sorry, but unlike some I don't have all the answers. There are only 2 of us so if the weather is really atrocious then we often don't put the roof up if we are very exposed. Otherwise try to get a sheltered position. Common sense should dictate what to do after all the roof is a large sheet of metal on 4 point supports with a piece of canvas. If a very strong gale can take off a house/factory roof !What if the wind has switched direction in the night , like it often does?
Many thanks for taking the time to reply with experienced information . Invaluable . ..Sorry, but unlike some I don't have all the answers. There are only 2 of us so if the weather is rally atrocious then we often don't put the roof up if we are very exposed. Otherwise try to get a sheltered position. Common sense should dictate what to do after all the roof is a large sheet of metal on 4 point supports with a piece of canvas. If a very strong gale can take off a house/factory roof !
People have even turned the van in the scenario you mentioned. You can drive it with the roof up. Not recommended but it can be done.
I spend a lot of time in Snowdonia and was up there to receive the tail end of the storms that battered the Lake District towards the end of last year.What if the wind has switched direction in the night , like it often does?
So with 2 parents sleeping downstairs and 2 kids in the roof the Cali is no use in windy conditions because if the wind pics up the roof needs to come down?I spend a lot of time in Snowdonia and was up there to receive the tail end of the storms that battered the Lake District towards the end of last year.
I sleep upstairs for preference leaving the downstairs as a sitting room. A couple of times the wind increased markedly overnight, way above what was forecast. It also became gusty repeatedly coming from different directions. Even though I was in a relatively sheltered location the Cali began to rock quite strongly. As @WelshGas says, the roof is held up on 4 point supports and is effectively a large sail as @Neilgbj says.
It is, apparently, very expensive to replace I have heard figures of £3,000-£4,000 mentioned plus the disruption. Lowering the roof in the dark, on your own at 3.00 in the morning is scary.
Getting your tail into the wind is the best advice, but be ready to move downstairs and lower the roof if you have to and plan a robust method of doing it under the worst scenario just in case it happens. I use a bungee and check the tension of it from time to time. They do loose their elasticity over time.
@Neilgbj and @WelshGas and others are quite correct, there is no definitive answer, but common sense prevails.
No different to a tent. You don't pitch a tent with the door into the wind, nor a caravan with awning, unless you want to see things sailing away in a gale. If the weatherman says gales are coming then use common sense if you have to have the roof up. No different to having an awning attached or the cassette awning out in stormy conditions.So with 2 parents sleeping downstairs and 2 kids in the roof the Cali is no use in windy conditions because if the wind pics up the roof needs to come down?
An internal Bungee? Never heard of that. Where can I get one? Thanks.Do look at my recent post 'bellows bungee belt and braces' : the bungee does not provide complete protection against damage to the canvas & roof by the rear part of the scissor mechanism. An internal bungee gives extra protection and is so simple to apply.
Understand now - looked up your earlier post. Thanks for sharing your idea.Do look at my recent post 'bellows bungee belt and braces' : the bungee does not provide complete protection against damage to the canvas & roof by the rear part of the scissor mechanism. An internal bungee gives extra protection and is so simple to apply.
