Depends if you are a member of the brigade that disconnects the gas before you drive or not, and I'm not going to open that debate again.Quick question fom a newbie yet to buy his first Cali.. Could the rear cabinet be modified to provide quick access to the gas (gaz) valve & said drain valve without having to clear & lift the bottom shelf? I read in another post that a member said ihe found it was a bit of a faff turning off ( & afterwards back on) the gas valve at the cylinder each time they went out due to its location. Sorry if its a daft question.
You'll get a 1001 opinions on this I'm sure ;-) I leave the gas on and turn off under the kitchen cupboard (controversial I know, but that's why the gas is in a sealed container under the cupboard shelf - at least that's my view). I personally empty the water tank and leave the drain valve open every time I've finished camping - why carry extra weight when you don't need it? Also keeps the tank aired and reduces the build up of slime (ever run your fingers round the inside of a drink bottle after you've left it to fester for a few days?!). The drain valve slackens off with regular use and it's a doddle to lift the bottom shelf (unless of course you leave the cupboard permanently filled with assorted spaff) ;-)Quick question fom a newbie yet to buy his first Cali.. Could the rear cabinet be modified to provide quick access to the gas (gaz) valve & said drain valve without having to clear & lift the bottom shelf? I read in another post that a member said ihe found it was a bit of a faff turning off ( & afterwards back on) the gas valve at the cylinder each time they went out due to its location. Sorry if its a daft question.
Did your T6 came with a manual?
Did you try and read it?
That's funny. You could always just suggest the poster is a muppet
I like your frankness Hotel, now I know you mean well, and know a lot aout the van......I asked about the straps in the draw when I first got mine......it was in the manual, but there was so much to learn in a short period of time.Thats an idea ....but we are here to make friends.
Guess some think i must offend them but i am just straight forward ( as you are when reading your reply's somtimes)
I don't even take the shelf out to turn the water valve( which I drain every trip, as I don't think stale old water is healthy)Quick question fom a newbie yet to buy his first Cali.. Could the rear cabinet be modified to provide quick access to the gas (gaz) valve & said drain valve without having to clear & lift the bottom shelf? I read in another post that a member said ihe found it was a bit of a faff turning off ( & afterwards back on) the gas valve at the cylinder each time they went out due to its location. Sorry if its a daft question.
