CALROE1
fitted sparesafe with standard vw locking spare wheel bolt is this long enough or do people fit one as long as normal retaining bolt Thanks.
Thanks KevIf the VW one does up then no problem it doesn't have to be longer
The short one is fine but if you're worried just put the long one back.![]()
Tighten up and see where the face ends up in relation to where it starts from. Loosen off and turn the face back to where you want it and beyond - clockwise by the same distance and re-tighten . It should then end up in the same position as you want. Repeat process if OCD kicks in until in the correct position that OCD is happy with.I bought a security bolt with the Spare Safe from the club shop. Are these a unique pattern or are they all the same?
And (my OCD is kicking in again here) how do you tighten it up without the spare safe rotating? The big red face with the warning sticker ends up visible from the side rather than the rear.
The one supplied with the SpareSafe is the long one. The normal bolt on the wheel carrier is just a generic bolt VW use to cover all eventualities .Hi Welsh,
The long one is ayk no security one.
If the short is really ok, fine. If a little risk remains it would be helpful to know if a long version is existing as well.
I understand that the security screw is a VW part but I can't find it on the web.
Cheers
Uwe
The long bolt is not a security bolt - all they need is a wheel brace to get it off. No mole-grips required.There are two lengths of locking wheel nut.
ZGB 701 071 592E - Short
ZGB 701 071 592 - Long
The short one - just about works with my 17" tyres on the steel spare, but only just took a couple of turns to tighten, so I replaced it with the longer one - which is pretty much the same as the long un-secure bolt supplied on the van.
The above picture shows the short one and the original un-secure one.
I don't have the sparesafe, so if they are going to get it off with mole grips I want it to be a long bolt so at least they have lots to work to do and they might take the skin the their knuckles!!!
