![Calicliff](/data/avatars/m/0/184.jpg?1484693756)
Calicliff
After having a rem. tow bar fitted I find I am unable to remove the key when removing the hitch and stowing it away in the storage box. Can someone explain the removal process please.
You got a box with yours?I did get mine out once with constant fiddling, but no idea how I did it, seems unrepeatable! It's mad that it doesn't fit in the box with the key in it and you can't get the key out!
mine came in a black plastic bagYou got a box with yours?
You reckon the tow bar fits in the toolbox? I'm too lazy to go outside now and find out.the tool box under the back seat .. it came with the van (before I had a towbar put on!)
+1 on this. Takes a little practice, don't turn the release knob all the way, just enough until you feel the tow hitch start to release from the vehicle, then let the know return.For the key to release when the tow bar is removed from the vehicle the knurled nut needs to return to the tow bar body and not be in the extended position that it needs to be in to fit or remove the tow bar (I'm talking about linear motion here, not rotation; you do both to fit and remove the tow bar).
Just extend and turn the knurled nut the minimum possible distance as you remove the tow bar and let it return (both rotation and extension) as the tow bar starts to release and drop down. It takes a little practice but you can get it to return to the tow bar body.
Then you can turn the key and remove.
You'll need to refit the key and extend to refit when the time comes....
Simon
