Front Roof Zip Opening Window Keeping Up Question
t6.1
t6.1
UK
T6.1 Ocean 150
Is there a knack for keeping this thing up?
It seems like there should be a button, clip, string, or something so you can roll it up and it stay up, rather than dangle down?
Although not ideal, I found a solution for this. By not opening it fully, it's then possible to tuck the material into itself :thumb
I’m just a little bit jealous of not having a front opening at the moment so can’t think straight;-)
You just roll it in on itself. As said leave the zips shut about 1cm and it holds ok. The older ocean bellow had a strip down the middle of the window which you could tuck it into
