sebking
What's the procedure for emptying the fresh water tank - getting colder and don't want it freezing!
Cheers
Seb
Cheers
Seb
I have read this somewhere as well......I think the thinking is along the lines of as the tap is full of water it can freeze and split the housing and the fuse removal is obviously to stop the submerged pump from running :roll:sebking said:Cool I had read some guff somewhere about removing the tap fuse and opening the tap.
Yes forgot to mention just ran tap for a second nothing came out so presume all is drained downCalikev said:Hi seb
I did this job yesterday.
Lift the shelf out above the gas bottle and towards the back of the van you will see a handle pull towards you
This will empty your fresh water tank it also helps to remove the freshwater tank filler cap speeds it up
Then close the tap replace filler cap job done.
