Code 2001
D
DaveB
Our 2016 Cali is showing code 2001 error on the panel diagnostic. Heater does not work and gives message “Roof open”
Anyone got any ideas how to fix this as we’re away in the van rn?
Cheers
Dave
I don’t have an ocean, but you could try disconnecting the starter battery live terminal, wait five mins then reconnect.
Control panel reset as WG in this thread
Cheers
Dave
Full Diagnostic codes. Unfortunately only cryptic descriptions.
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Thanks all, I had tried the reset procedure but pressing the centre button does not clear the errors on my 2016 Cali.
Turns out lowering and raising the roof made it all go away.
I think I have a slightly dodgy control unit as well. The rotary dial is becoming increasingly hard to use as it needs pressure to move between items which causes random flicking up and down the menus.
That's going to be my next forum search ;-)
Hi. I had what sounds like the same problem: heater lamp flashing and unable to turn the heater on. Thanks to Welsh Gas for the very helpful and clear instructions above. I followed these, getting error code 2001. I had just opened the pop-up roof beforehand. I then followed the panel reset procedure but this didn’t start until I closed the pop-up roof. The heater works now. I was worried it had been caused inadvertently by some work carried out on my vehicle last week. All good now - phew!
Hmmmm, code 2001. Do the doors suddenly lock themselves while an electronic voice from the control panel says "I'm sorry Dave, I'm afraid I can't do that."???
(Sorry, not much help but reminds me I must re-watch the Kubrick movie).
:upsidedown
Here’s what the message said, so nothing as sinister as that, fortunately. I’m just left a little curious about how the system got into that state. However, all’s well that ends well :)
R
12K
PaulBastowski
P
L
Lost in the Forest
L
