Alarm going off when in vehicle???
L
Lisa Stafford
T5 SE 140
Hi
Seem to have an issue with the alarm going off in the night. The doors are closed & when we get up to use the loo in the night the alarm keeps going off. Anyone any ideas what is being done wrong?
Lisa
Are you locking yourself in with the key fob ?
If so don't, use the central locking button on the drivers door to lock yourself in at night.
Or if you wish to dead lock yourself in, disable the internal movement sensors with the button on the pillar by the drivers door.
Hi
Lisa
Try the switch on your drivers door pillar
You want the amber light showing when inside and the doors are locked
Alan
Aaahhh, Yes you are right, I have used the key fob to lock it, Thanks so much for that, will try the one on the driver pillar.
Lisa
You can also use the keyfob but need to press it twice. Once to deadlock and alarm and the second press turns off the alarm and deadlock. (That is what happens on mine anyhow...!)
Sent from my HTC One using Tapatalk
Don't forget the locking switch in amongst the mirror adjuster/window switches on the drivers door, this is how we lock ours at night.
Painted Pilgrim
Painted Pilgrim
Painted Pilgrim
5K
GrannyJen
GrannyJen
David Eccles
6K
Bluestone
Bluestone
Judyl
13K
Broch Hunter
Broch Hunter
