Back from another 8 week trip
sbmcd
sbmcd
Edinburgh
T5 SE 180
Just back from another 8 week Euro trip. Sailed Newcastle to Ijmuden with DFDS, booked as a large car as it fits the size spec.
Usual no plan apart from follow the weather, originally hoped to travel via Germany to Austria but weather directed us to the Ecrin NP in France where is was still hot at 1500 metres. From there the Quayras NP, Lac Sainte Croix then Provence.
Van behaved perfectly apart from a slow puncture (rear) on the day we were about to start our journey back north. I thought I'd fit the spare that should be easy, used the level ramps to make the spare easy to remove. Located the jack and breaker bar plus extension and set about the job. Wheel came off easily enough but soon discovered the centre of the spare was so corroded there was no way that was going to fit. Finally used the spare as an axle stand for safety while I used my plug repair kit to fix the punctured tyre.
Whole job took less than one hour, I suppose I could have called out breakdown service but that would have taken much longer for sure.
Only 2,523 miles this year, and my 180 bi turbo used no oil at all as usual and still drives like new at 130k miles.
Looks like some cracking campsites - where are they? We did the NC500 a couple of weeks ago which was great, but thought we might head for somewhere warmer next year!
Also, which tyre repair kit do you have - there are loads available and I'm sure a fair few of them are rubbish, it would be great to have a recommendation. Did the repair hold out ok and did you get it professionally repaired when you got back?
Nice trip, I took my 12 year old away for the last two weeks of the summer holidays and we ended up in the Gorge du Verdon. It is a beautiful area.
We spend some time there this year at Salle sur Verdon and Castellane,it is beautiful and usually a good area for weather when the weather turns in the high alps, and only 3 - 4 hours drive.
Top photo is at La Berard campsite in the Ecrin NP
Second at Ailefroid also in the Ecrins NP
Third as Salle sur Verdon.
4,5,6. And 7 wild spots
8 at St Andre Les Alps.
The kit I use I got from Demon Tweeks, small kit for motor bikes but I've added extra repair strings and glue over time. If the repair is on a slow and it's not been run flat I'm happy to just plug it as a permanent repair but if it's been run flat it's likely there is internal damage so any repair would be temporary and require internal inspection.
It is usually possible to repair the fronts without taking the wheel off, just need to find the leak point and turn the steering to make it accessible. I have repaired a rear while still on the van but it depends where the puncture is located.
Used this every time, never had an issue
It is usually possible to repair the fronts without taking the wheel off, just need to find the leak point and turn the steering to make it accessible. I have repaired a rear while still on the van but it depends where the picture it located.
Great, thanks. We've been to Alp d'huez a couple of times, but only in the snow - we've always said we should go back in the summer!
We were in Annecy and the weather was rubbish so we headed south until the sun came out and ended up in Huttopia Verdon gorge. We did white water rafting in the gorge and paragliding at St Andre Les Alps. We had our paddle board with us and used it to explore the bottom of the gorge at Lac de Sainte Croix which was great but very busy, we also went up to Lac de Castillon which was very quiet and had a paddle there. It was great and seeing the vultures was awesome.
