At the risk of stating the obvious have you checked the fuse in the socket ?My waeco CF 35 fridge doesn't work when you plug it into the 240v only runs off the battery cable I have bought a new cable. No joy. Does anyone know a place around the Warwickshire area who can repair this? View attachment 104531View attachment 104530
Check 12v fuse.I have a Waeco CF-40, and it works perfectly on 240v, and also works on 12v in my car, but recently stopped working on 12v in my Cali beach. However, another fridge that I tested works perfectly in my Cali on 12v
Any suggestions would be greatly appreciated
Most good quality portable fridges have a cut off if the supplying voltage drops below a certain level. Unless your California battery is fully charged then high resistance connections, such as the 12v socket you are using, or long cable runs can drop the voltage and switch the fridge off to protect the battery. Try another 12v socket or better still fit a dedicated socket with thicker wires suitably fused direct to the battery.I have a Waeco CF-40, and it works perfectly on 240v, and also works on 12v in my car, but recently stopped working on 12v in my Cali beach. However, another fridge that I tested works perfectly in my Cali on 12v
