Cube Fuse
GrumpyGranddad
GrumpyGranddad
Wendover
T6.1 Ocean 199
Thinking of buying a cube fuse for my Spares Box. Can somebody advise the rating for a Cali’ Ocean, is it 50amp or 75amp? And is it the same rating for both Leisure Batteries and the Starter Battery? I know I can check but just being lazy!
There is only 1 Cube Fuse, on the rear Leisure Battery.
However there is a 80 amp fuse on the alternator supply to the Front Leisure Battery, found under the front passenger seat,RHD.
Thanks @WelshGas
So is this correct?
75amp cube fuse on rear leisure battery
80amp Pearl Maxi fuse under front passenger seat
Is there a cube fuse for the Starter Battery?
I don't think that the cube fuse is anything
to have in your locker. The early models were
upgraded but you will have to
