Tyre covers to prevent cracking?
DG1
DG1
East Midlands
First MOT found cracking on the Bridgestone tyres on our Ocean, which was first registered 3 years ago and has done 11000 miles.
Is it worth getting tyre covers to protect against UV and other damage when the tyres are replaced? If so, what do people recommend?
Never had that on any vehicle. Photo of the cracking?
Where do you store it when not using? Indoors or Outdoors?
It's parked outside in the drive. I have found earlier threads about tyre cracking in similar age tyres, suggesting it is relating to low usage and effects of UV light. e.g.
If it’s parked in the sun, then covers might help, but low usage and remaining in the same position for weeks on end won’t help.
You could hyperinflate the tyres, it might help.
Cars in extended storage are usually jacked up, wheels removed and stored stacked horizontally and turned over on a regular basis.
Alternatively, use it more.:thumb
