kaoskitn
Hi all.
I've read through the English translation of the T4 California Westfalia (1992) manual and I still cannot figure out exactly how to deal with these two issues that I have, so I thought I'd hit you all up and see if you can help out:
Many thanks in advance!
Cari
- Is there a way to delete all of the timer settings for the heater, or to just make sure that it doesn't turn itself on while it's parked?
- I've turned the gas under the van all the way, counter-clockwise (in the direction of "zu", which means closed) but the gas still works on the stove burner when the valve under the sink is on, which makes me nervous about driving. Am I missing an additional switch or something to turn gas all the way off?
- The dash controls stay on after I've parked and drain battery. Is there some sort of master "off" or "park" switch or button somewhere to just make sure that batteries aren't drained while parked? I tried flipping the breaker switch above the fuse box behind the driver's seat and that doesn't seem to have any effect. (I believe it's for the 230v input)
Cari
