Temperature selection drivers side
Cheapround54!
Colchester
Just browsing
F37E7D47-44A2-400F-9689-25918582D863.jpegHi all
The temp selector will no longer change the actual temp. It has been taken apart by an Autoelectrician and the whole unit needs replacing .
Has anyone managed to fix it without spending an absolute fortune please?
Any advice would be appreciated.
VW California 2012.
It depends on the fault-code. It can be the a PCB or it can be a servomotor. And then, after replacement, it may need softwareupdatees which not every technician can do.
Thank you. There is no fault code. This is the heating temperature control not the control panel unit.
