K
KBR
Thanks for this. Really appreciate it. This will be a weekend job for me. I don’t remember seeing that black end cover on my doors, is that something you added? What’s it for?Sounds like you’ve saved a bit of ££ which is a good result. You may want to consider some Araldite-plastic to extend the life a bit.
You will have read/noticed that the doors ‘hang’ from the top brackets rather than sit in the guide channel as may seem logical. Accordingly you have the option to adjust how high/low they hang by making adjustments in the places pictured (4 x Allen key bolts across the 2 brackets suspending each door). If the rattle is driving you crazy then you may wish to loosen them off and lower the door by 1-2mm at a time until the amount of friction with the lower guide rail is sufficient to stop the rattle. Good luck!View attachment 74227
